WOT Timing? for Big Cam, Heads, High Compression on pump gas
Old 03-14-2006, 01:33 PM
SlickVert's Avatar
Default WOT Timing? for Big Cam, Heads, High Compression on pump gas
I am running ET 215 heads 58cc, T-Rex cam, .040 gasket with the SCR @ 11.84 and DCR 8.6.
I am just trying to get some advise on tuning time for this kind of set-up prior to me spending a lot of time on the dyno to figure out what most have already learned.
With this kind of set-up what did your timing curve look like and how much timing were you able to run and where.
Thanks
Bob
Old 03-14-2006, 08:39 PM
WS6FirebirdTA00's Avatar
of course its all dependant on waht the car wants but a dip in timing around peak torque and to ramp up after taht. i would start safe maybe in the 25-28* range and fine tune on the dyno
Quick Reply: WOT Timing? for Big Cam, Heads, High Compression on pump gas
