Anybody change the analog output of a LM1 for more resolution?
Coal Mining Director
EFI Live default for the lm1 is 1v = 10.0 : 1 AF Ratio.
So your only using 0 to 1.4volts...pretty narrow.
Could command lm1 to 0 to 5 volts.
Anybody doing that?
Anybody doing that?
LS1TECH Sponsor
Here is a great thread with lots of wide band configuration information:
http://www.hptuners.com/forum/showthread.php?t=2941
Kleeborp the Moderator™
Yep...mine is set to:
0-5V = 11:1 - 17:1 AFR
Output = 1/12th
When I'm doing VE table tuning, I have my configuration setup in the scanner so that I can log at 40 frames per second...I wanted as much resolution as possible when making that table, especially since I run open loop full time.
Output = 1/12th
