Able to connect (hptuners) last year fine, now i cant!
Used Hptuners all last summer, stored car and installed new parts. Now when trying to connect to scanner, it says, cable not found on 3 and 4 and then goes idle. I unplugged everything and then plugged it back in, tried again and it said Connected and gave me a voltage in the bottom corner, so I hit the play button to start scanning and then the "trying to reconnect" window comes up and thats it. It connected only the one time and now I cant get anything!
Any ideas?
THanks
Any ideas?
THanks
Confused. Why does that matter? Cigarette lighter has to work to power my Laptop since there is no battery in it.
Added info: At first I thought that I might have screwed up the wiring or something when I installed the 408 but I have a couple of other interfaces and software packages that I sometimes use and the one that I tried worked fine so.........................
Havent tried that. Will it help?
Ok, so when I receive the error, if you look at the top of the window, it says UNKNOWN VIN ERROR
WHat the heck is this about?
Suite Info:
VCM Editor:
ERR:
VCM Flash: 1.7.0
ERR:
VCM Scanner: 1.7.0
ERR:
VCM Suite Opt: 0 0 0 1
VCM Suite ID: 00000A7199
Suite Info:
VCM Editor:
ERR:
VCM Flash: 1.7.0
ERR:
VCM Scanner: 1.7.0
ERR:
New update. I tried a different computer with the SAME cables. It connects to the scanner intermittently which is somewhat good. Problem is it wont read or write the VCM. WHen I try to write, it asks what file I want to use, then it starts working and comes back with a "download request timeout" error.
Anyone?
Anyone?
are you using a USB-serial adapter? if so what brand?
The issue is communications related:
1. bad serial cable (they can break from constant bending)
2. low quality USB-Serial adapter
3. slow PC, try reducing RX buffer size
http://www.hptuners.com/help/introdu...hooting.htm#c2
this can also happen if your PC was just ok, but then installed a processor hungry virus scanning s/w etc.
4. bad connection on vehicle ODB2 connector (the pins can lose tension or come loose. rare, but it does happen).
Chris...
Chris...
Chris...
Chris...
