LS1 coil pack pinouts
I recently aquired some LS1 truck coil packs. I will be using these in a coil-per-cylinder application that is not on an LS1. I was wondering if anyone on here knows what each pin on the coil pack is. On the connectors it says A, B, C, and D. A and B are black and brown respectively, on all the coil packs. D is pink on all, and C changes colors for the different connector. So what do A, B, C, and D hook up to?
Thank you to all those who reply!
Thanks WILWAXU. I started another in Conversions and Hybrids and got the information I needed! So you can delete this thread if you would like.
