front 02 code
front 02 code
i threw front 02 low circuit voltage the other night at the track it completely turned my car off when i did a burnout and then it started back up. when i ran the quarter i got all the way through first gear (A4) and it did it again and the pedal goes all the way to the floor im guessing because of fuel trim. Anyone had this problem?
Sounds like you have an electrical wire flopping around creating a short or open due to g forces. Your O2 error is due to a lack of voltage and your gas pedal going to the floor is your cruise control going whacko, if I understand your question.
