Are there any disadvantages when...???
...using Speed Density tuning. I mean, even if it only gains a couple horsepower, why wouldnt everybody choose this option. Most people try to squeeze out every last bit anyway right so why not here too??
it is squeezing the last couple bit of hp out of the car.
The disadvantage is you lose some compensation for the tune in different weather conditions, since you are "telling" the computer how much air is coming into the engine, vs calibrating the sensor that measures the airflow coming into the engine get get correct fueling.
Ryan
Ryan
The MAF compensates a lot for tuning errors.
SD mode does not, so you must do a much more thorough job of getting the tune right. A lot of people don't want to invest that much time.
So its probably not the most or most pratical option for a mostly street vehicle. I want to get every last bit of power out of my car but this almost seems like its not worth it.
^^^ all depends on how much time you want to spend scanning and tuning
I run SD on my TA... but it only sees the street 2.5 seasons a year on nice days and only a few thousand miles
LS1TECH Sponsor
I always try to dial in the ve/maf tables and throw the car back into closed loop/maf...since the maf can still make alot of adjustments when adding mods. Most people add one thing at a time rather then throwing 10 grand at a car all at once...keeping the maf in play for most is the best way to do it.
you can get the same amount of power out of both a MAF and SD tune(in theory), but the problem is that inorder for a MAF tune to be spot on your VE(SD Tuning) must be dead on. Therefore the amount of time to get a MAF tune is not worth it to most people with a Tuning suite. Thats my take on the situation.
Like I said I've never done this, but I don't see why you couldn't do it.
There's something in the code already to the effect of swapping to fuel calculation at 4000 RPM. I'm not sure yet what that means though. A good tuner could sort it out in a short time in any case.
