Please Help: Checking trans temp??
Hey guys my converter is going in tomorow and i was wondering what software would be applicable to check that? I have a hypertech on its way from ebay, would that work? If not would myscantool.com, autotap? either of them work i didn't see their trans temp sensors on their site.
Moderator
AutoTap should, I know my old EFILiveV6Pro did and
HPTuners does. Transmission Fluid Temp is probably
the name of the param. You could also tap the two
wires at the PCM, measure voltage and work back to
a temp using the info in the Helm books if you aren't
quite ready to dollar up for the software yet.
can you tell me more about the checking the voltage thing because right now i am kinda strapped for cash to spend 500 bucks to just check the trans temp or get a gauge for a couple hundred i would just like to know for a cheaper method thanks man in advance.
