Were do you do this at HPT?
Were do you set the output of the Wideband side should be set to 1/12 or 1/6th second output-update rate
output of the Narrowband side should be set to 1/6th second output-update rate(best simulate the response of the stock o2 sensor
In HPT.
In HPT.
Originally Posted by MeentSS02
That's done on the wideband's side...not HPT. You have to tell the wideband to do it. The HPT software has nothing to do with this.
That's why I could not find it. I was looking for it in HPT.
Thanks for the fast reply.
Moderator
The key is, they need to be consistent. You can look at
the HPTuners standard transfer curve and set the LM-1
/ LC-1 to the same, but you might prefer to get more
resolution & less error, by compressing the range some
and then you'd have to set them both up and hope they
remember. Which is not to be taken on faith. I know my
LM-1 has "forgotten" settings on me before.
Kleeborp the Moderator™
Set the LC-1 to output a set voltage across all AFRs (like 1.0 volts). Then, with your HPT scanner, log the Raw Voltage (instead of the standard AFR). See how far it is off. To make it even better, you could even verify the LC-1 voltage output with a third-part device (your handheld multimeter) just to make sure it is actually putting out 1.0 volts.
Gather a few data points, and go from there. Most of this is covered here:
http://www.hptuners.com/forum/showth...=ground+offset
What firmware do you have in it? Some of the earlier firmware versions had connectivity problems.
Basic things to check:
Make sure terminator plug is fully seated (I think it has to be in the IN cable)
Make sure serial -> 2.5mm cable is fully seated.
Make sure the LC-1 has power (as in, turn the key to ON)
If those all check out, just keep connecting and reconnecting the wires, and keep opening and closing the program until it does connect. Sometimes it is a little bit stubborn.
I'm not sure what that is.
I've checked everthing else pluged and unpluged opened and closed. Nothing works.
