F1R Procharger HP Tuner Base Map Needed
I am in the process of building my F1R Procharged 402. I will be using HP Tuners SD Programmer and a MSD 3-bar MAP sensor. I need a base map to atleast get the engine start and broke in before going to the dyno for tuning. I know there are a few of you out there with supercharged motors and using HPT. I just need something to get me started. Can anyone help?
What size injectors are you running? I am building something similar and plan on running 75# injectors. Just can't decide on high impedance or low impedance with a res. box!
Originally Posted by foff667
posting a copy of your file would be a good start
LS1TECH Sponsor
Originally Posted by RednGold86Z
http://www.horist.com/hptuner/
maybe something in there, I dunno.
Well, you do have a point that no one has done it with the really big injectors. But I have seen many others tune their 800+whp FI motors using HPT. I was hoping to hear from them. I will offically tune the car on the street and the chassis dyno with a wideband. If anything, does anyone know a good starting program and/or advise, so I can get the engine started and maybe safe enough for break-in and some part-throttle tuning.
