Done with tune... What now?
I have spent the better part of 3 months messing around with this thing, and I decided to finish it up this weekend. I went through and tuned just about everything applicable. I am using HPT w/WB to tune. What do you normally do to finalize a tune? What histograms should I be checking out? Does anyone have a histogram made that compares the commanded AFR with the WB signal? I think this histogram already exists and comes with the software, but I don't know which one I should be using (VE or MAF error). I assume the "test" for a good tune is if the difference between commanded and actual is as small as possible.
Thanks in advance for your input.
Jeremy
Screen shots to follow from my final tune.
And the file itself...
http://www.savefile.com/files.php?fid=1850103
Jeremy
