Problems changing to PE
I have a 06 Silverado.I have been learning how to tune now for a little over a month.I have a problem with my truck not wanting to go into PE.I can do some 0-100mph blast and it will only go into PE after it changes to second gear,it seems to be in Stoich all through 1st gear.What do I need to do? I have changed the delay rpm to 1000,The map to 90,the hyst to 2-all this still does not make it change.I might have changed something before by mistake??? I also read in a post on HPtuners forum that there was a problem with the new 06s going into PE?Please help?
mine reads....
MAP = 0
Hyst = 0
delay rpm = 0
enable torque = 0%
dis torque = 15%
enrich rate = 4.000
These settings basically make it jump into pe whenever it reaches the required TPS.
Chris
MAP = 0
Hyst = 0
delay rpm = 0
enable torque = 0%
dis torque = 15%
enrich rate = 4.000
Chris
Moderator
PE mode delay RPM wants to be set low, enrichment
rate to 1.000; enable TPS to something mid-scale
and PE enable MAP to something above idle MAP
observed. Seen a post recently about some sort of
%-torque which I guess is a drive by wire deal, I
have not seen this on my vehicle. You have to jump
all these hurdless to get PE and you'd prefer they be
easier to clear.
easier to clear.
