WOT shifts points w/ HPT still bad!!!!
I have a 4000 stall, w/ a 26" tire and stock 3.23's and have my WOT Shift RPM vs. Shift at 6400 on the 1-2 and the 2-3
my WOT Shift Speed vs. Shift is 45 for the 1-2 and 74 for 2-3
but its still taging the limiter on the 1-2 which is set at 6600!!!!!!!!!!!
Russ Kemp
sometimes 200 rpms leaway on the 1-2 shift isnt enough thats why many use mph rather then rpms as the main trigger on the 1-2.
Do you have 3.23 or 3.73 gears? Post your file and I'll take a look at it.
here you go... my lasted bin
EDIT: files to large, even zipped?
Originally Posted by Doc
Your WOT Up Shift at #Speed is > than your WOT Down shift correct?
What I am getting at is you didn't just jump in and adjust one and not the other?
