iac counts high at cold idle
Old 04-25-2006, 10:31 PM
Jpr5690's Avatar
Default iac counts high at cold idle
when my car first starts my iac counts are in te 170's as it heats up they drop to zero.. how do i fix this
as of not my set screw is removed but i have a 9\16 hole in my tb blade
also i notice my stit starts out low (-.2 lb\min) and it slowly works its way up to (-.91 lb\min) as the car warms up
if anyone is intrested i have this all loged in a 8 min warmup hpt log it shows all the idle pids so hopefully if someone views it they should really have a good idea whats going on...
thanks!
-john
Old 04-26-2006, 12:40 AM
SmokingWS6's Avatar
Have a large cube motor, heads/cam or aftermarket throttle body? One or all of those combinations can change the effectiveness of the IAC.
I've seen some large cube motors commanding 310 steps if started cold with the a/c on and steadily drop to 0 as it warms up. Normally this is caused by the motors demand for air outgrowing the iac's effectiveness.
Old 04-26-2006, 06:49 AM
Jpr5690's Avatar
ms3 cam and ported heads
Old 04-26-2006, 07:25 AM
Doc
Doc's Avatar
Desired Airflow vs. ECT combined with the right TB set screw adj.
Old 04-27-2006, 06:15 AM
Jpr5690's Avatar
any other table affect desired air flow i tried using redhard supers's spreedsheet but it kept on telling me to lower my raf values ???
also how do i know how much to pull\add to desired airflow?
Old 04-30-2006, 11:44 AM
SmokingWS6's Avatar
If the car still runs at 0 counts, no amount of airflow adjustment would make a difference. Is the motor over revving when its up to 170 counts?
Old 04-30-2006, 12:52 PM
Jpr5690's Avatar
Once Counts Are At Zero Idle Is Fine But When The Car Is Cold The Iac Couns Are High And The Idle Hunts
Old 05-08-2006, 05:17 AM
99whitews6's Avatar
Did you ever figure this out?
I think this could be my idle problem as well. My RAF is in-line, and my startup A/F is where is needs to be, but my startup idle hunts until the IAC values drop down. I too see IAC position below 10 when its warmed up and it idle nicely.
Old 05-14-2006, 01:10 AM
Jpr5690's Avatar
no, i went outa town but now that im back im gonna be diggin back in to this prob here shortly
Old 05-14-2006, 01:11 AM
Jpr5690's Avatar
im thinkin the prob may lie in some sort of airflow modfier table thats values are depdent on ect
Quick Reply: iac counts high at cold idle
