Safe tuning
Old 05-06-2006, 12:50 PM
aboadnan's Avatar
Default Safe tuning
Hi to you all, i know this is mostly LS1 but more people come here,
is there something for LT1 like the LS1 where you don't fry the PCM
Thanks.
Old 05-06-2006, 02:58 PM
silverTA2002's Avatar
Fry the PCM?
What do you mean? Who fried their PCM?
Old 05-06-2006, 03:11 PM
aboadnan's Avatar
Originally Posted by silverTA2002
Fry the PCM?
I mean that if there is power failure or cable disconnect during programing
you loose your PCM meaning car no start.
Old 05-06-2006, 05:54 PM
Just be careful.
Tuning takes 28 seconds with HPtuners. Not much room for error.
But, according to HPtuners, you're ok as long as you don't turn the ignition off. (Never gonna try it though).
Old 05-06-2006, 06:32 PM
2xLS1's Avatar
Just be careful.
Things are a little more risky in the LT1 world. I don't know of any choices other than LT1Edit or Tunercat. Both have been known to fry a PCM or two unfortunately.
Old 05-06-2006, 11:06 PM
SICK WS 6's Avatar
I've probably done over a thousand LT1 reprograms, and I've never lost a pcm.
I'm sorry, but if you do it's either user error or you didn't check the connections or battery (car and computer) before starting.
Always do a read before you do a reprogram on an LT1, watch what you're doing, use your head and you won't lose the flash chips.
