EFILive will not recognize cable?
Everything was working fine yesterday morning. Modified a tune, uploaded, did some logging, made a few more changes to the tune. Went out to log and nothing.
Now I cannot connect with EFI Scan or Tune? Any ideas? Error message indicated a possible fuse problem with OBDII connection. ?? Maybe they are referring to the ALDL. If so, anyone know where that fuse is on C5?
TIA
TIA
I am trying to find out if what circuit my ALDL could be on? I checked both lighter circuits and no blown fuse. I looked at each fuse and could not see a blown. I guess my other option is to pull each fuse and check them one at a time.
What a PITA!!
What a PITA!!
Originally Posted by Bill Bowling
I had the same problem with my Camaro and it was the fuse. The connector on a Camaro uses the same fuse as the lighter.
Bill
Bill
Sure enough, blow fuse.
Thanks again...
