Hey there fellas!! I need HELP!!
I recently had a trual dual x-pipe put on my vehicle. My car ran fine except for there was some rubbing along the floorboard. I took it to a gentle man to get the rubbing out of the exhaust and now when I got my car back, around 3500 rpms I get backfire. Now the backfire only happens in Drive. In neutral and park I have no problem getting to 6k and I can hold it and no surging. The problem I get is when I go to get in it and when I am going up hills I can feel the vehicle surge atbout 2k because i was scared to get it to 3k and cause it to backfire. I retorqued my long tubeheaders and I am about to run outside and see if putting my factory mass airflow sensor will fix it. I also believe I could have a blown header gasket but I cant see if its blown. PLease guys this is my daily driver.
Have you checked for any other possible leaks in the system?
Chris Macellaro
all leaks in exhaust have been fixed. I pulled the driverside exhaust manifold gasket (the paper one) and when I held it by one end it snapped in half. needless to say I need a new one. I'll find out if that fixes the problem when i get off work today
Dude I think you are exactly right. My question is I wonder if its from the cam which has only been in for a month or from the long tube headers which have o2 sensor simms thathavebeen in for about 1 year.
also i have noticied it smelled extremely rich lately. I definitely think I am gonna go get a tune ASAP!! I think the cam is hurting a little but dang i put new plugs in a year ago. I might just get some wires just to have some upgrades. Any reccommended plug other than OEM for a motor with cam/heads? any reccommendations?
