PLX WB 02 Reading 13.60-13.62 in all cells
Old 05-18-2006, 06:39 PM
Chalky's Avatar
Default PLX WB 02 Reading 13.60-13.62 in all cells
Just got my PLX hooked up, model M-250. Logging data in EFI. Problem is when I log data, any number of cells are being hit but AFR stays @ 13.60-13.62. PLX has no calibration feature. Cra has mild tune and is running with MAF.
Any one have any ideas?
Old 05-18-2006, 08:07 PM
Purrvert's Avatar
Log both the EFI black box inputs, you are probably logging the wrong one. The input that's not used just drifts. Are you using the PLX for narrow band simulation?
Old 05-18-2006, 08:34 PM
Chalky's Avatar
No NB!
Old 05-18-2006, 08:54 PM
Purrvert's Avatar
Got a voltmeter, digital preferably. Check the orange plug for 0 to 5VDC. +-5 volts with power on and engine not running, indicating lean condition, this may take a few minutes.
Old 05-18-2006, 09:15 PM
Chalky's Avatar
Voltage to EFI connector was spot on. At idle, voltage was 2.3 and drops as RPM's increased. 2.3 volts equates to 14.6 at idle. When i checked data in EFI, voltage was a constant 1.8 and AFR was 13.6
Old 05-18-2006, 09:37 PM
Purrvert's Avatar
Which pid are you logging 1 or 2 and what terminal are you hooked too?
Old 05-18-2006, 09:47 PM
Purrvert's Avatar
Looking at the black box. With the bi-pin on the left that's A & B next is C-PLX1, D-Ground and then E-PLX2.
Old 05-20-2006, 07:37 PM
Chalky's Avatar
This was it. Thanks
