Emission test results >
Old 05-24-2006, 04:17 PM
99SSragtop's Avatar
Default Emission test results >
HC ppm - limit 55, mine 55
CO % - limit .31, mine .28
NO ppm limit 408, mine 215
Looks like a little unburnt fuel is getting by at 39 km/h 25 mph
Oh well a pass is a pass.
Not sure if a ported MAF would of helped.
Old 05-24-2006, 05:18 PM
Wnts2Go10O's Avatar
get a dyno run in and find out what your af is.. u might be a smidgen rich.
Old 05-24-2006, 05:39 PM
gyrene2003's Avatar
what kind of cut-out do u have?
Old 05-24-2006, 06:22 PM
Camaro ChriSS's Avatar
Good stuff. Glad you passed the spectre...
Old 05-24-2006, 07:47 PM
99SSragtop's Avatar
Z'd style cutout.
Old 05-24-2006, 08:12 PM
Brett H's Avatar
Thats odd, your HC ppm limit was 55 yet mine when I tested in april was 58 ppm max and I have a 99 too.
Anyhow, your headers are causing the rich condition down low. I had the same problem when I did mine and some data logging with HPT showed that the pcm was trying to pull fuel. A bit of fiddling with the tables fixed it right up.
Old 05-24-2006, 09:10 PM
joecar's Avatar
What are your LTFT's...?
Old 05-25-2006, 04:59 PM
Brett H's Avatar
I think I was about -11 at about 40km/h which is where the test is performed but without going back in my log, I am only guessing.
Old 05-25-2006, 06:31 PM
SmokingWS6's Avatar
Looks like canada? i'm assuming has not converted to obdII based testing. If they ever do you can run whatever mixture you want
Old 05-26-2006, 08:20 AM
99SSragtop's Avatar
Last test 2 years ago ( stock exhaust) limit was set at 60.
I may get it dyno tunes at Autoworx soon and be done with it also.
