A4 Downshift problems
Old 05-30-2006, 10:30 AM
Z'mnypit's Avatar
Default A4 Downshift problems
Im tuning an 01 TA, A4 H/C, built trans 12 bolt etc. Well Got everything dialed in, but the trans will not downshift. You can put it in overdrive running 55mph then floor it, & it will stay in OD. The only way to get it to down shif is to manualy pull it down. The car shifts fine under part thorttle, & WOT. just want downshift under WOT. Ive changed everything I could with HPtuners to get it to down shif & it will not. Am I missing something here?
Old 05-30-2006, 11:55 AM
SSpdDmon's Avatar
Did you try reloading the default/stock settings for the trans from your stock file and then adjusting for gears if need be?
Old 05-30-2006, 11:58 AM
wickedwarlock's Avatar
I would try putting it back to stock, just as he said. And check the fluid.
Old 05-30-2006, 01:31 PM
Z'mnypit's Avatar
Well. Ive copyed & pasted all the stock values from a stock tune to the tune Im working on & still nothing. The car had already had tunning done to it before so I never had the stock tune to start with.
Old 05-30-2006, 02:05 PM
SSpdDmon's Avatar
What tuning software are you using? Does it have a compare feature? With EFI Live, you can download a stock tune from the EFI Live or HPTuners repository and view it/save it. Then, if it's the same OS you can use the compare feature and copy the entire Transmission Calibration and Diagnostic segment in EFI Live. That way you don't have to copy individual tables. Don't know if HPT has that same feature.
I owe that little helpful piece of knowledge to Jesse (aka wait4me). Thanks Jes!
Old 05-30-2006, 02:40 PM
Z'mnypit's Avatar
Im using HPtuners. Im not sure if there is a compare feature or not. There isnt that many charts that had to be copyed anyways.
Old 05-31-2006, 09:08 AM
there is a compare feature.
Old 05-31-2006, 12:51 PM
Z'mnypit's Avatar
Yeah I seen that after I posted.
What are all the downshift tables zero'd out for? Ive looked at 4 tunes & they have all be 0's. Whats up with that are they not used? Im talking about under shift properties/Downshift they are all blank.
Old 05-31-2006, 02:32 PM
SSpdDmon's Avatar
Shouldn't be...I don't have any 0's in my shift tables. A few 256's, but no 0's.
Old 05-31-2006, 03:03 PM
Z'mnypit's Avatar
Under where it says downshift? 2-1, 3-2, 4-3? I can post a screen print if I need to.
Old 05-31-2006, 05:01 PM
jdaniels's Avatar
They're definately not zeroed on a stock 99 file. Mine were actual numbers stock.
Old 05-31-2006, 05:05 PM
Z'mnypit's Avatar
Anyway you could email that to me? Ive still yet to find a tune that actually has numbers entered. zmnypit@alltel.net
Old 05-31-2006, 05:12 PM
Z'mnypit's Avatar
Here is a screen shot of my bone stock tune from my 99 z28. See the tables?
Old 05-31-2006, 09:03 PM
SSpdDmon's Avatar
Those are pressure modifier tables based on trans temp (ie if the trans is shifting too hard cold or not hard enough hot, you modify those tables). I thought you were talking about MPH tables. Those pressure tables are supposed to be 0'd out stock.
Old 05-31-2006, 09:15 PM
Z'mnypit's Avatar
Well that makes sense now. Im starting to think the trans is screwed
Old 05-31-2006, 11:34 PM
DrkPhx's Avatar
Look under "4>3 Throttle Kickdown". It's based on TPS and MPH. Try changing the values to 85% or so for all mph. That should help. If not if could be the solenoid, but generall that will throw a code.
Old 06-01-2006, 10:26 AM
Z'mnypit's Avatar
What table is that? I dont see anything like that.
Old 06-01-2006, 01:24 PM
SMOKINV8's Avatar
This is the third time I've got some use out of this screenshot.
These values aren't from an F-body, but it shows what you need to modify. The 1->2 shift is an upshift, the 2->1 is a downshift. Make sure none of those conflict with each other.
Old 06-01-2006, 01:32 PM
SSpdDmon's Avatar
Good screen shot....just make sure you're adjusting "normal" shifts with "normal" shifts - not "normal" with "hot."
Old 06-01-2006, 02:35 PM
Z'mnypit's Avatar
Thanks! Yeah I thought that was the tables being talked about. Ive changed those numerous times with the stock #'s in place & with me modifying them & still nothing. Thats why im begining to think the trans is screwed.
Quick Reply: A4 Downshift problems
