trading PCMs - LS1TECH
PCM Diagnostics & Tuning HP Tuners | Diablo | Pantera EFI
trading PCMs
Thread Tools Search this Thread
Old 06-15-2006, 08:21 PM   #1
Default trading PCMs
Can you switch a PCM from a 95TA to a 94Z28 just to check and see if the 94 PCM is bad?It stays in closed loop all the time and its throwing a **** load of codes.But will not read any changes in TPS,EGR,timing,and alot of other strange crap.Any help is appreciated.
slamm69 is offline   Reply With Quote
Old 06-15-2006, 08:39 PM   #2
fast377's Avatar
I think you can, but I can't remember if 95 was obd1 or 2? I know 94 was obd1.
fast377 is offline   Reply With Quote
Old 06-15-2006, 08:59 PM   #3
Quote:
That should have been my question,are both of these years obd1's?If not what will happen if I try to switch them out?
Old 06-15-2006, 11:53 PM   #4
horist's Avatar
OBDII was not mandated until 96 model vehicles... some manufacturers went to OBDII earlier than 96, and GM went to an OBDII style plugin in 95 I believe.... but the PCM should be OBDI
As for if the 94 and 95 PCMs are plug and play... I have no first hand experience w/pre LS1 PCMs so not sure on that answer..... but I can say with good certainty 95 was OBDI
as for what will happen if you try to switch them out.... I'm guessing the plug that attach to the PCM wouldn't fit... since OBDII has many more wires than OBDI
But as I mentioned... I don't know if the pinout and/or physical PCM are the same (but I would imagine they are.... 99-02 F-Body's were the same basic hardware/pinouts)
horist is offline   Reply With Quote
Old 06-16-2006, 01:05 AM   #5
fast377's Avatar
Quote:
Thats what the deal was...I knew there was something different about the 95s.
Old 06-16-2006, 10:53 PM   #6
Can someone local like a dealership or autozone test the PCM?
Old 06-17-2006, 03:14 PM   #7
shaun's Avatar
i think the worse that will happen is it wont start. had the same thing on a 91 taurus and got a pcm from the salvage yard and it hooked up fine but it wouldent start
shaun is offline   Reply With Quote
Old 06-21-2006, 09:35 PM   #8
Does anyone know if a bad PCM will make the speed-o off?I checked the code in the glove box and checked the gears and both say I have 3.23's.But the speed-o is like 20 to 25 MPH fast at 70 MPH.I havent had the PCM checked yet I was just wondering if maybe someone else had had this problem?Would there be anyyhing else that might throw off the speed-o-meter?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
