Rough Startup After Cam - LS1TECH
PCM Diagnostics & Tuning HP Tuners | Diablo | Pantera EFI
Thread Tools Search this Thread
Old 06-18-2006, 04:06 PM   #1
00transamnh's Avatar
Default Rough Startup After Cam
is it usual that the car wants to die out when you first start it up with a new cam in it? My car likes to die out for some reason (even after getting tuned). After about 15 seconds of running it idles perfectly
anyone have any ideas?
00transamnh is offline   Reply With Quote
Old 06-18-2006, 05:49 PM   #2
ringram's Avatar
it might be usual if you have a bad tune.
If you have a good tune, then its not.. Issue is likely to be running airflow (desired airflow in efilive)
Can also be a few other things, like timing and some of the other startup parameters (cranking, initial enrichment etc) but more often than not its running airflow table.
ringram is offline   Reply With Quote
Old 06-19-2006, 12:41 PM   #3
technical's Avatar
Sounds like the initial enrichment timer considering it takes ~15 seconds to straigten out. I wonder if something is off a bit causing the PCM to throw the wrong amount of fuel.
Does it do this during a warm restart, or just a cold start?
technical is offline   Reply With Quote
Old 06-20-2006, 08:04 PM   #4
doesnt matter... can be cold or warm... does the same thing
irritating as **** tho, noone elses cammed car does this
Old 06-20-2006, 08:06 PM   #5
Tech fanatic
Black02SS's Avatar
Alsmost sounds like the tune as ringram stated.
Black02SS is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
