Today I tested the difference between SD and MAF mode both in open loop (Dyno inside)
Old 05-20-2006, 10:40 PM
HumpinSS's Avatar
Default Today I tested the difference between SD and MAF mode both in open loop (Dyno inside)
For the sake of avoiding OCD i decided to go back to MAF operation for sometime to see how i liked it and if there was any difference. To my surprise the number between the MAF and SD were within .5 HP of each other. Here is the dyno graph that shows the proof
The car was dialed in using SD mode first and then some WOT power runs were made. THe maf was then hooked up and dialed in (fule only no timing changes) and I made some WOT pull with the maf. The graph appears to be off by one HP but that is because the decimal placed were truncated. These numbers were aquired on a Mustang Dyno using the Dyno Jet simulation. Run 1 denotes SD operation and Run 2 is the MAF. Enjoy
Old 05-20-2006, 10:47 PM
Bink's Avatar
Cool! Thanks.
How does the part throttle responsiveness compare...MAF vs SD??
Does dialing it in SD and then going back to the MAF help PT??
Old 05-20-2006, 10:52 PM
HumpinSS's Avatar
MAF operation feel smoother/softer i assume this is because the maf damps a lot of the pulses compared to the map senosr. I will keep eveyone updated when i drive it more
Old 05-20-2006, 11:41 PM
txhorns281's Avatar
Excellent
Old 05-21-2006, 04:13 AM
TAQuickness's Avatar
very cool. so you gonna keep the MAF?
Old 05-21-2006, 07:52 AM
SideStep's Avatar
SWEET!!!
How much overlap @ .050 does that cam have???
Old 05-21-2006, 08:40 AM
HumpinSS's Avatar
Somewhere about 20* if I have the specs right but since the specs arent published I can only guess
Old 05-21-2006, 09:08 AM
SideStep's Avatar
HOLY CRAP!!!
Part throttle (non-PE) driving has to be better in SD, right???
Old 05-21-2006, 09:11 AM
HumpinSS's Avatar
I will let you know it a week or so my Desired airflow and throttle cracker tables need to tweaked a little they were a little off in SD mode and still off in maf mode. I was being lazy. Other than that PT driveablitly feels about the same. The load dyno helped keep the driving conditions the same for both setups so they feel REALLY similar. after a week when the car settles in and I get a better feel for it i will report back
Old 05-21-2006, 10:04 AM
Teutonic Speedracer's Avatar
Good test and post! Thanks!
Old 05-21-2006, 11:15 AM
Black02SS's Avatar
Awsome results Larry!! Keep everyone updated.
Old 05-21-2006, 01:13 PM
LS1TECH Sponsor
foff667's Avatar
cool findings Larry
Old 05-21-2006, 06:13 PM
Billiumss's Avatar
Exclamation
I've read online that SD tuning gives you around 20 more HP over a MAF tune, glad the truth is out now... J/K
Anyways, good post, MAFs aren't THAT restrictive as some people might think they are.
Thanks for sharing...
Old 05-21-2006, 07:18 PM
GuitsBoy's Avatar
Thank you for the good info... Like you said, I think the MAF softens part throttle up a bit if you tune it directly from dynamic airflow. Instead, I leaned the maf out just a bit with some help from MAF AFR histogram and part throttle livened up again by not over fueling transients. I find that once you dial in the MAF, some of the minor bucking and surging goes away and it handles changes in weather a little better too.
Old 05-21-2006, 07:19 PM
2MuchRiceMakesMeSick's Avatar
Great comparison.
Thanks for posting them up
Old 05-21-2006, 07:38 PM
Phoenix 5.7's Avatar
cool comparo. goes to show that a properly dialed in maf can be as good as SD, at least at WOT.
Old 05-21-2006, 07:40 PM
Moderator
jimmyblue's Avatar
Screened or descreened?
Old 05-21-2006, 07:53 PM
HumpinSS's Avatar
descreened z06 maf
Old 05-21-2006, 08:21 PM
DarkFormula's Avatar
Heh, except for FI '98s
Old 05-21-2006, 09:00 PM
98redorangeta's Avatar
Nice post glad someone took the time to post up and actully SHOW that there isnt a power differance between the 2.
I think he still had the maf in place when he tuned it SD just had it turned off. So the restiction part of the maf dosent come into play but that would be another good test to show the gains with out a maf in place to see if it is a restriction.
Quick Reply: Today I tested the difference between SD and MAF mode both in open loop (Dyno inside)
