wtf? did my car somehow loose its tune?!
Old 06-22-2006, 06:14 PM
00transamnh's Avatar
Default wtf? did my car somehow loose its tune?!
Well this is all a week after my car got tuned on the dyno....
I was driving down the road and i saw my SES light come on (i was near autozone) so i had em check it out... They told me that i threw codes
P0405 (egr voltage is low)
P0140 (insufficient activity from o2 2 in bank 1)
P0160 (insufficient activity from o2 2 in bank 2)
P0300 (some missfire bs)
heres the thing... when i got my car tuned i had him turn all the egr and the rear o2s off
WTF happend to my 400$ tune! why is this **** showing an ses light
also... could p0300 and the o2s be related? If not what could be the problem? is My Air fuel messed up?
Old 06-22-2006, 06:33 PM
yak
yak's Avatar
i wanna know toom, same thing happened to me a week or two ago.
Old 06-22-2006, 06:35 PM
2001NBMZ28's Avatar
No way you just "lost" the tune - bring it back.
Old 06-22-2006, 06:37 PM
redtail2426's Avatar
what he said,bring it back
Old 06-22-2006, 06:53 PM
01'WS6's Avatar
Mine has done the same thing and i took mine back 3 times and its still doing the same thing. Same codes but throw a TPS on in there too.
Old 06-22-2006, 07:09 PM
ZL1Killa's Avatar
the tuners don't know how to cut off all the egr stuff..
you must cut them off in the DTCs and the MIL status
Old 06-22-2006, 07:34 PM
k thanks ill see what he has to say
Old 06-22-2006, 07:51 PM
01'WS6's Avatar
Keep us informed on what you find out because ive been searching for the answer to this problem for a month now.
Old 06-22-2006, 10:45 PM
my tuner said he did both of those... any other suggestions?
Old 06-22-2006, 11:17 PM
01'WS6's Avatar
Mine said the same.... Think there is any kind of relay or anything that would have caused this?
Old 06-23-2006, 01:18 AM
ZL1Killa's Avatar
they must have missed one. I have turned mine off and not had a problem. here is the list: NOTE THIS ALSO INCLUDES OTHER THINGS . I could be wrong and there could be something else going on, but I honestly don't think so. try unplugging (if it still on the car_ and plugging it back in
O2
P0137 HO2S Circuit Low Voltage Bank 1 Sensor 2
P0138 HO2S Circuit High Voltage Bank 1 Sensor 2
P0140 HO2S Circuit Insufficiency Activity Bank 1 Sensor 2
P0141 HO2S Heater Circuit Bank 1 Sensor 2
P0157 HO2S Circuit Low Voltage Bank 2 Sensor 2
P0157 HO2S Circuit High Voltage Bank 2 Sensor 2
P0160 HO2S Circuit Insufficiency Activity Bank 2 Sensor 2
P0161 HO2S Heater Circuit Bank 2 Sensor 2
P0420 Catalyst System Efficiency below threshold Bank 1
P0430 Catalyst System Efficiency below threshold Bank 2
EGR
P0400 EGR Flow Malfunction
P0401 EGR Performance
P0402 EGR Excess Flow Detected
P0404 EGR Pintle Position Error
P0405 EGR POS sensor low volt
P1404 EGR Pintle Closed Position Performance
P1406 EGR Pintle Position Error
P1409 EGR Vacuum Leak
AIR
P0410 AIR System
P0412 AIR Solenoid relay control circuit
P0418 AIR Pump Relay Control Circuit
P1415 AIR System Bank 1
P1416 AIR System Bank 2
Old 06-23-2006, 01:19 AM
ZL1Killa's Avatar
you could ask to see that they are turned off. **** happens, people do miss stuff. I have done it plenty of times on my car
Old 06-23-2006, 09:28 AM
Street Lethal's Avatar
Yeah, find a new tuner.
As mentioned, bring it back to the tuner and have them re-set everything for you. I'm sure he might have said that he disabled the EGR entirely, but he must have overlooked something...
Old 06-23-2006, 09:39 AM
ZL1Killa's Avatar
cars don't just lose their tunes. print out the whole thing i posted above and take it to him and have him turn all that off, well if you want. Otherwise turn the EGR off
Old 06-23-2006, 09:53 AM
moehorsepower's Avatar
There are error codes that have to be turned off also, if they just turned off the first or second error then it will come back on. It has to be off completely..
Old 06-23-2006, 09:54 AM
ok thanks guys ill have him check it out again
hes more of a mustang guy anyway
Old 06-23-2006, 03:47 PM
get this... my ses light went out on the way home
wtf?
Old 06-23-2006, 04:35 PM
11SECDWS6's Avatar
wtf?
Check all your plug connections on your entire wiring harness. Mine was throwing alot of codes also. I went through and found a couple of plugs that were not snapped on all the way. When I did this all of the codes magically disappeared...
Old 06-23-2006, 08:13 PM
01'WS6's Avatar
wtf?
Mine did the same thing too. I think we have a case of the devil cars or something.
Old 06-23-2006, 08:24 PM
BLM (Block Learning Mode)...
