lc-1 help plz
lc-1 help plz
Ok so. I have the yellow wire in terminal C. Green and white are in terminal D. and brown wire in E. I am using a cigret liter plug for the power, witch i have the red wire hoked too. I have the Blue wire hooked to the ground of the Cigret lighter. I had to get an addapter hookup for the serial port to the back of the laptop. And i Get please connect the device to a serial port and turn it on. Any ideas?
I had the same issue (still unresolved).
Things to check, Com Port assigned to your adapter try and set it for comm 1 or 2 this is most common, not sure what com ports the software is able to search, but it should be able to do at least com 1 or 2.
Are you using an additional serial cable? If so there are 2 types, be sure to use the right one (I think one is staight through, and the other is called a null modem cable that I think has a crossover, I think the straight thru is whats needed). Try without the "other" serial cable if your using one.
Good Luck!
Good Luck!
