Painless harness swap
Has anyone swapped their engine harness over to the Painless on (p/n 60506 or 60507). I've been going over the harness and I cant find the oil pressure sensor wire on the new harness. Also, how will this harness tie into the body control module?? Im a retard when it comes to wiring, so this is a big leap for me- any help/critism is appreciated
sawzall wielding director
Why did you swap to a painless harness?? I have never worked with or used one. There may not be an oil pressure sensor wire since the harness is made for installation into older vehicles and most of the time the LS1 oil pressure sensor will not work with the gauges in the older vehicle, you usually just install the sensor from the older vehicle and run your own wire.
I don`t think the painless harness has any way to tie into the BCM either since in 99% of the swaps into older cars you do not use the BCM.
