Vague LS1 Edit Tune Question
What does this tune consist of? How much can be gaines off of it too?? My plans, i want to get the EGR, A.I.R. turned off, Skip Shift Light and Rear 02's turned off too.. Can the LS1 Edit do that?? i also want to get the a/f ratio perfect for oeak HP and TQ in the proper Power Band..
so again can the LS1 Edit do that? Or does another porgram do all this.
sorry for a vague question. i ask a lot of question that is how i learn.. i like to read too. Still new to the LS1.
Thanks for your help in advance!
Any tuning suite can do what you need it to do whether it's LS1 Edit, HP Tuners or EFI Live.
Read this: https://ls1tech.com/forums/pcm-diagnostics-tuning/368718-read-me-best-ls1-tuning-software-best-scanner-best-handheld.html
Read this: https://ls1tech.com/forums/showthread.php?t=368718
i just want to know the difference between ls1 edit vs all other tunes
Originally Posted by joecar
LS1Edit is a tuning software package and not a tune; the user of it can create/adjust a tune using this software (or the other software packages).
LS1Edit, HP Tuners and EFI Live are the software packages programmers use to make the tune. They all can do what you need them to do.
