Idle/rpm falls almost to dieing while in Open-Loop
Old 06-29-2006, 10:35 AM
SideStep's Avatar
Question Idle/rpm falls almost to dieing while in Open-Loop
Idle/rpm falls almost to dieing while in Open-Loop, when I pull out or stop quickly. After Close-Loop all is fine…
Any quick guesses???
Old 06-29-2006, 10:58 AM
ringram's Avatar
cracker and RAF
Old 06-29-2006, 11:11 AM
SideStep's Avatar
Originally Posted by ringram
cracker and RAF
Yupper.. I got RAF dialed-in, but I am confused why it ONLY manifests itself in Open-Loop...
Old 06-29-2006, 11:15 AM
HumpinSS's Avatar
*2 for Throttle cracker
Old 06-29-2006, 11:21 AM
Moderator
jimmyblue's Avatar
Any excess enrichment will make the idle loop more
"soggy" and prone to overshoot. I expect closed loop
is fixing this for you, making the idle loop more "taut"
as a result.
Old 06-30-2006, 09:41 PM
SideStep's Avatar
Well after much trying and testing of different Throttle Cracker settings I still cannot get this beast to idle when pulling out or stopping quickly (while still in Open-Loop).
Everything is fine in Closed-Loop.
Is there a specific process I should us for changing the Throttle cracker table???
Old 07-02-2006, 05:37 PM
P Mack's Avatar
Try this https://ls1tech.com/forums/pcm-diagnostics-tuning/533938-here-s-how-fix-rpms-dipping-when-coming-stop.html
