the new inspection stuff
has anyone got inspected lately and you not have cats on your car? they say this new inspection stuff can tell the temps and all that.
anyone have new info?
I will post up a picture of where we got our van inspected and all that it reads on the paper soon.
the place i got inspected at says its a new software and 16pin connector, reads temp and a bunch of other stuff
i don't have cats, i have the codes turned off. I will get the picture up of the scan here soon. but will the computer show it as me not having cats?
this is the new software update that came i think in January, has anyone gotten inspected that doesn't have cats?
Well I have to get inspected in July w/ longtubes, no cats, no egr, no air in charlotte. Codes have been deleted. I will let you know how it goes. Any ideas of places that dont open the hood?
"Tampering Inspection" - weird. When I was in Wake County only got a visual and sniffer test, but was a couple years ago - heard they were going to OBDII only.
That is nothing out of the normal, that is the visual inspection that is performed. If the codes are deleted they have no way of telling. The wya the testing works is it looks for a trouble code, if its there, it makes sure its emission related, if it is it fails. If the SES light is not enabled, it doesnt look for codes and passes, so we will pass. Whoever you talked to apparently didnt want to inspect and pass your car so they are feeding you a line of bull ****.
Originally Posted by foff667
has anyone running SD been able to pass the new plug & play emissions? If so how? Ses off & no error reported?
From my understanding that's not 100% true.... from what I understand, they (govt) currently don't check to see if the OS is stock... however, I've heard from a few sources that they (EPA inspection places) actually download the full PCM flash when they connect...
If this is the case... they can tell if the PCM is alterred... but thing is it's not currently worth the effort to check (since there are so many OS's for a given model year... imports are even worse than the LSx PCM I believe)
For now though they just check for an SES and the readiness tests
