How to clear vin out of Hypertech Programmer?
So it's got another vehicle's VIN in it still? Unless something has changed recently, you're screwed. The only way to clear it is to hook it back up to the original car and put it back to stock since it's got that original car's stock tune stored in it. I got screwed a few years back buying a hpp3 off ebay for cheap. Guy said he put his car back to stock but didn't. Hypertech doesn't offer any kind of reprogramming service either....believe me, I tried.
yes there is way
this is what i did
1.go to Oreillys warehouse that flashes computers (or any where that can flash a vin to your computer)
2.flash your computer to the vin in the HPP3
3.install computer in car and the HPP3 will find the correct vin and then you can "return to stock"
4.reflash your computer to your stock vin and program
now i got to do that for free since i worked for oreillys but im not sure of what it might cost you if anything, i think its is $20 for a flash
i did have some issues with getting the HPP3 to work by doing it that way, but i did get it
this is what i did
Ed do you have any additional info on what you need to change (high octane/low octane, tire size, gear ratio, etc). If I just saved my current tune, then loaded back the stocker and changed the VIN could I just hook up the hypertech and remove the tune? Then change back to the new tune and be good to go? Would the auto-M6 thing create any issues?
9-Second Club
Originally Posted by 98Blubrd
I was thinking about this once. I thought I saw a place that you could change your Vin through HP Tuners? If so couldnt you just do the same. I have an old hypertech that was not put back to stock and was thinking of doing this to, however the car that was tuned with the hypertech was an auto and my car is a M6 so I didnt want to risk messing something up.
Originally Posted by Ed Wright
Changing the VIN, in a vehicle with a different trans just won't work. They use different calibrations, and the HPP will see it is differet and won't program it. Don't wast your time.
