how do tune these injectors?
Old 07-11-2006, 05:36 PM
camarokid94's Avatar
Default how do tune these injectors?
Delphi/Lucas 42# High Impedence Fuel Injectors
bought them form thunder racing?
thanks
Old 07-12-2006, 07:22 PM
jpolser's Avatar
redhardsupra.blogspot.com - check out the right hand column, and click on new injectors spreadsheet. Click on the HPTuners tab (it defaults to EFI LIve) once you are in excel. Insert the values of your injectors, I believe they are 42.29 at 43.5 psi..It'll give you the new numbers. Copy, paste into hptuners.
Old 07-13-2006, 07:23 AM
thanks man!!
Old 07-13-2006, 07:44 AM
RedWS6 00's Avatar
Yep I agree with that. I have the same injectors from Thunderracing. I used that 'redhardsupra' spreadsheet, and it was spot on.
I did aldso fiddle with the minimum injector pulse width, as it would never go below 1.8ms, needed to go down to 1.2ms.
Old 07-13-2006, 08:02 AM
muncie21's Avatar
The Delphi's react quicker than the SVOs so min pulse width and offset-vs-volts-vs-kpa may need to be adjusted (down).
Old 07-20-2006, 06:35 PM
LOL what does that all mean......?
Old 07-20-2006, 06:47 PM
the last two posts??
Old 07-20-2006, 06:49 PM
WOW tha spread sheet RULES!!
