Ann Arbor, MI Area - $50 for someone to do re-learn and clear P1336 SES code.
Old 07-13-2006, 03:48 PM
todddchi's Avatar
Default Ann Arbor, MI Area - $50 for someone to do re-learn and clear P1336 SES code.
EDIT - Request already filled - thanks!
Hi,
Picked up a P1336 SES code because Diablosport had to wipe and restore my ECM from scratch. I need someone with tuning software that can do the learn procedure and wipe the code, or I suppose a Tech II if anyone actually as one.
Don't want to go to the dealer.
Ann Arbor / Plymouth MI area.
PM please.
Old 07-13-2006, 04:01 PM
wait4me's Avatar
Email me, ill fix you for free.
Old 07-13-2006, 05:37 PM
SSpdDmon's Avatar
Elaborate on learn procedure? Is that TPS?
Old 07-13-2006, 09:25 PM
todddchi's Avatar
I don't know perfectly but if you search P1336 lots of threads come up. It is the crankshaft position sensor - needs to "learn" to each motor I guess, but not every time. Just bad luck.
Need a tech II or tuner software to do it, simple to do I guess if you know how.
Old 07-13-2006, 10:35 PM
SSpdDmon's Avatar
A crank relearn....did you have the motor apart or did you replace the sensor?
I'll be up in Lansing this weekend. Maybe I can swing by on the way back and we could give it a go depending on how things go this weekend?
wait4me's Avatar
If the computer has been cleared in that area or a new pcm was used it needs done also.
Old 07-13-2006, 10:54 PM
todddchi's Avatar
My original predator failed during loading and totally locked the ECM. Diablosport had to "factory restore" my ECM, and sent me an updated predator.
Things were fine for awhile but the code popped just the other day. Thier tech support acknowledges this happens on a small percent of cars, so I am the lucky winner.
I'd appreciate an effort from someone local, but at the same time I'd mostly like someone who has been through it before, has the software, and can do it for sure. Otherwise I'll just suck it up and give the dealer the $50.
Old 07-14-2006, 09:29 AM
todddchi's Avatar
wait4me has very kindly offered help, but is not local. I am still looking for a local tuner if possible...
Old 07-14-2006, 09:30 AM
wait4me's Avatar
Anyone with efilive can do it for you, it takes 3 seconds for the proceedure with it.
Old 07-14-2006, 10:57 AM
Scooter70's Avatar
Can you drive the car to my house? I've never done a crank relearn (is that the same as CASE Learn?) but I'm sure that my HPT scanner can do it. Shoot me your # and we can figure out a time to meet somewhere.
Old 07-14-2006, 11:01 AM
horist's Avatar
Yup you can do it in HPT... just be sure to follow the instructions in the help file. It's part of the Bidirectional control area in the scanner
Old 07-14-2006, 11:56 AM
Scooter70's Avatar
Thanks for confirmation Mike.
Toddchi - I'm free on Sunday. Let me know.
Old 07-14-2006, 12:05 PM
pman's Avatar
I can also help, i have HPT for 2000 if you need something anything removed.
Old 07-14-2006, 12:07 PM
fast98's Avatar
i can do it for free if you want, i have a tech 2 and hptuners
Old 07-14-2006, 02:51 PM
todddchi's Avatar
Scooter, I would drive to Auburn Hills Sunday, no problem.
Fast98, where are you located?
Thanks!
Old 07-14-2006, 03:02 PM
Scooter70's Avatar
Thanks!
I'm in Farmington Hills.... much closer to you than Auburn Hills. However, if pman is offering to do it and he has HPT for any 2000 F-body, he will be able to do other things for you (remove CAGS, etc) that I can't do without using 2 $50 credits. If he's local and will hook you up, I'd go see him. If not, I can still do it for you. (I won't take your money either.) It looks like you have 3 options. Let me know if either of the other two guys don't work out and I'll do it Sunday afternoon.
-Matt
Old 07-14-2006, 03:43 PM
todddchi's Avatar
I don't need anything else done, I am fine with the tuning flexibility the Predator has to offer. All I need is the Tech II equivalent functionality to do the learn procedure and clear the code, no actual tune or programming work. I want to keep the standard predator functionality and not risk buggering up anything that might confuse the predator. They seem pretty touchy.
If that costs you any credits I will happily pay.
Oh, and I just typed Auburn Hills by accident, Farmington is fine. I'll PM a phone number if you could just let me know a time and address I'll be there. I doubt I'll do any better and that is pretty close to me.
Old 07-14-2006, 03:55 PM
pman's Avatar
I'm in Waterford so Farmington sounds to be closer... if he cant help pm me and we could meet up.
Old 07-14-2006, 04:47 PM
fast98's Avatar
im in shelby twp
Old 07-16-2006, 10:12 AM
Scooter70's Avatar
Todd came up and we fixed it this morning. It took all of 30 seconds. Glad I could help. HPTuners rocks.
