what after VE tune
no i used my ltfts to modift my ve table when not in pe mode and below 4k rpms now i want to know weather i should somehow tune my ve above 4k rpms or leave the me mode off and do maf tuneing or tune the pe without a maf?
I Have A Wideband But No Eio
Do I Need A Wideband To Tune The Maf?
My Plan Was To Use The Ltfts To Tune My Part Throddle Stuff, Then Dial In The Maf (not 100% Sure How To Yet) Then Set My Pe Multipliers By Using My Wideband Gauge And The Tach
If you're not going to use a wideband, you need to do this, which is taken right out of the sticky at the top of the forum.
After that you can do the maf like this, which is taken right out of the sticky at the top of the forum...or you can use the histogram right in HPT.
Did you read this sticky from the top of the forum?
