Part Throttle Tuning.....
Old 07-23-2006, 01:13 PM
LS2 Pontiac GTO's Avatar
Question Part Throttle Tuning.....
Ive been tuning my dads LS2 Goat with his predator. ive goat everything pretty much dialed in for WOT. In part throttle im still getting what I think is a lean condition cause just a bit of KR, heres the numbers.
  • 3255 RPM
  • 1.76 Degrees KR
  • LTFT -2.34%
  • 62% Throttle Position
  • 0.75-0.79 O2 Sensor
Should I continue do richen up the Power Enrichment in the mid range?
Old 07-24-2006, 08:47 AM
SSpdDmon's Avatar
PE is for WOT and higher loads during part throttle. Because it's a handheld, you're going to be very limited to what you can change. If you weren't in PE when you experienced the data you posted, then it's out of your control.
