Debaffled WS6 Hood, AFR now off.
As the title says, I removed the baffles today. Previous WOT runs I was about 12.9 - 13.1. Today I'm at 11.9-12.1. No PCM changes were done. If the AFR got a little leaner I could expect, but getting richer, has got me baffled (excuse the pun)
Would any one expect it to get richer? and why? just trying to get an understanding.
My MAF is reading about the same. 27lb/min @ 4400rpm. infact pretty much the same in second gear.
IAT Temperatures are about the same.
One thing I noticed is that at WOT the LTFT's read +6. But looking at the whole LTFT logged map nothing is about +1 or below -1. Everything is pretty much spot on.
Perhaps it was just an oddity on that run, will do another run shortly and see if my AFR is back to 13:1 or still near 12:1.
In the past since my last change it has been running 12.8 to 13.1 at WOT constantly, no drift. As soon as I remove the baffles it dropped. If you use 13 AFR and work out the +6 Fuel trim you get 12.22 which is pretty close to what I'm seeing on the wideband. I think I need to find out why my fuel trim went to +6 at WOT when all other cells are very near zero.
