Request for evaluation of logged data...
Old 07-31-2006, 03:15 AM
Rich Z06's Avatar
Default Request for evaluation of logged data...
I had a custom tune done on my Diablo Predator for my '02 Z06 with long tube headers, cat & X pipe, and new air cleaner with Shaner TB. Nothing extravagant.
I didn't bear down hard on the go pedal, obviously, so high revs aren't evident here. But still, I'm just a bit concerned about the timing advance in the 2K to 3K rpm range. Any opinions?
Next time out I'll try to log in the 4k+ range to see what the data looks like.
BTW, this log was created using the CarChip module, in case that makes any difference. It only takes samples at 5 second intervals.
I'm using a link here because I think the file size may exceed the limits on this forum.
http://www.corvetteflorida.com/photo...to=272&cat=507
Thanks for any help.
Old 07-31-2006, 07:29 AM
SSpdDmon's Avatar
Usually when they adjust timing, they just adjust it for WOT areas. The timing you see in your log looks normal. My car sees upwards of 41* stock from the factory when I let off of the gas.
