28lb injector offset voltage table
Old 08-06-2006, 11:31 PM
jgaytan's Avatar
Default 28lb injector offset voltage table
Hey guys,
I wanted to install a set of 2001 LS-1 28lb injectors in my fuel injected 351 windsor motor (ford I know). Anyway I dont have EFIlive or HP Tunner or anything of the sort. The closest thing I found to finding a stock LS-1 injector offset voltage table was the following http://ls1edit.slowcar.net/iotest1.xls I just dont know if the stock injector offset voltage table listed in that excel sheet is for 28lb injectors. Could anybody please either post a injector Offset voltage table like in the excel sheet listed above or send it to me at josegaytan28@hotmail.com? Any help would be appreciated.
P.S. I have added Ford SVO fuel injector Offset voltages, I only ask that you help me with obtaining Chevy fuel injector offset voltages for 28lb injectors and maybe even the 26lb injectors. If you could do something in the same format that would be awsome. Thanks in advance
File Type: zip
Old 08-07-2006, 12:01 AM
2xLS1's Avatar
Check your mail.
Quick Reply: 28lb injector offset voltage table
