will PO481 and/or P0507 cause knock retard
Moderator
'98s have a known knock sensor problem, have
you replaced yours with the part type that
supersedes them, '99-up?
Your two codes are cooling fan 2/3 relay and
idle speed high. The fans might make for some
hot-weather, after-high-load ping but I doubt
the idle speed has to do with anything. Though
with the mod list and mystery tune, who knows
what non-code-setting mixture / spark influence
might be present?
might be present?
