Vats Screwing Up My Car!!
Anyone ever have problems withthe VATS and their starter? My car won't even turn over. The accessories come on but when i turn the key further there is no response from the starter. Please help
Have you got a spare key? If so, give it a try before you start troubleshooting hardcore. Sometimes over time, the contacts on the chip in the key get worn down enough that they don't make contact like they should. If a good connection isn't made, the car doesn't "see" the key in the ignition as being the right key.
Check out my post and responses from Mr. Dude over in the conversion section. 88 GTA w/ LS1, sounds like same problem. If you wait 3 to 4 minutes and try again does it start right up?
I'm going to give the contact cleaner a shot and hope it helps. May have to go find a new key for this one if that doesn't work.
Mines got the same problem now.. It throws the BCM code 2723.. Its the pass key sencer and its not telling the motor to Crank you will need to take it in to the dealer and have it fixed.. Its about $250.00 Iv gotta have it done, Or if you want the VATS turned off it will crank, But It will not fix the problem just a band-Aid
not to sure if mine did the same thing all the gauge lights up but nothing so i check the voltage at the stater wire and nothing so I disable the vats and so far no problem.
(I have a new battery,HD starter,)
cool i went to a GM garage and they want 55$ to "diagnose" the problem, but most likely they think that it is the key reader in my ignition. Could the key reader really be that unreliable? I only have 45k on my car and it's a 98ss.
