SD vs. MAF pro-con??
Old 09-07-2006, 11:37 PM
Ionize's Avatar
Default SD vs. MAF pro-con??
In the process of putting a 402 LS2 in a '01 Z06. The cam is 239/248 .649/.615 110LSA +1, 3.42 gear stock weight. Car will be ready to tune in about 10 days. Weekend car, 1000mi max/year. My tuner seems to be wanting to back away from a SD tune, I think it should be worth it. What do you guys think? Pro's and con's?? How much more $$$ for a SD tune, with/without dyno time. Thanks!!
Old 09-08-2006, 12:05 AM
LS1TECH Sponsor
foff667's Avatar
https://ls1tech.com/forums/showthrea...=speed+density
Old 09-08-2006, 05:54 AM
LS1Tech Sponsor
Slowhawk's Avatar
You really don't need a SD tune.With a MAF tune it can run perfect.There is absolutely no power difference between a good SD tune and a good MA tune.
If the Cam was bigger,I might push SD for low end throttle response.
Old 09-08-2006, 10:04 AM
ZL1Killa's Avatar
years after years... trashing the MAF is still around.
don't do it. your car will run fine with the MAF and you won't notice a difference without it. IF TUNED RIGHT. and MAF tuning i think is easier than MAFless tuning, as i'm used to doing it too though
Old 09-08-2006, 11:31 AM
Ionize's Avatar
I think then I'll have him do a MAF tune then, he says he can get drivibility fine, which was my biggest concern. I'm not biased either way. Thanks!
Old 09-08-2006, 11:53 AM
SSpdDmon's Avatar
Yeah, I usually recommend tuning with the MAF as long as it's not being pegged. Even then, some have managed to still use the MAF (if you look at that 'other' thread that's been at the top recently). Unless you switch to forced induction, you shouldn't have to worry about that.
Old 09-08-2006, 03:59 PM
LS1 Tech Administrator
Patrick G's Avatar
With the MAF, you can run a dry shot of nitrous and you can set your timing tables to pull lots of timing at the higher grams/cylinder cells. I run up to 30 degrees NA and 20 degrees across the board from .96 gr/cyl up. 20 degrees works well for making over 600 rwhp.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
