9.5:1 CR 346, H/C, D1SC, 14lbs, Alky, 100 octane.....what kind of timing?
Im very tempted to go super aggressive with the timing, given that I will be running 100 octane+alky in the car.
I was thinking tune it on a 95-ish blend of 100, 91 and plus alky, and then run 100 in it on a regular basis. Am I able to crank up timing, theoretically. Want to make big fawking power.
The timing should be less at higher rpm with a centrifugal blower..
Here is my map, 9.5:1 346 with a D1 @ 14-15psi and 104 unleaded - no meth. I dont know if I make big fawkin power or not but if you get more agressive then this you will most likely be shopping for a new short block soon
**** thats EXACTLY what I wanted to see. Thanks KP!
I would probably not go as far as you did, since its not just a drag car, but I wanted to see what others did, as far as I recall, I was only set up at around 15 degrees for pump gas and no meth, and was curious as to what the aggressive guys were doing on better fuel.
Thanks!
Thanks!
LS1Tech Sponsor
