42lb injectors
It will be the same regardless of year.
LABELS Injector Flow Rate (Lbs/Hour)
Manifold Vacuum kPa {link: GM.MANVAC} Value
0 48.487790
5 48.797814
10 49.107838
15 49.417862
20 49.665882
25 49.975906
30 50.285930
35 50.595954
40 50.843974
45 51.153998
50 51.464022
55 51.712042
60 52.022066
65 52.270085
70 52.580109
75 52.828129
80 53.138153
0 48.487790
5 48.797814
10 49.107838
15 49.417862
20 49.665882
25 49.975906
30 50.285930
35 50.595954
40 50.843974
45 51.153998
50 51.464022
55 51.712042
60 52.022066
65 52.270085
70 52.580109
75 52.828129
80 53.138153
Hi Black02SS
I find the numbers below with my calculation for my Lucas 42 lb. per hour high impedence fuel injectors
These fuel injectors will flow 42.5 lbs. per hour at 43.5 psi, my car is a 2002 ZO6.
I use those value, is there something wrong?
Injector Rated Fuel Pressure: 43.5
Your Fuel Rail Pressure: 58
Injector Rated Flow Rate: 42.5
0 49.08
5 49.38
10 49.69
15 49.99
20 50.29
25 50.59
30 50.88
35 51.18
40 51.47
45 51.76
50 52.05
55 52.34
60 52.63
65 52.91
70 53.20
75 53.48
80 53.76
0 49.08
5 49.38
10 49.69
15 49.99
20 50.29
25 50.59
30 50.88
35 51.18
40 51.47
45 51.76
50 52.05
55 52.34
60 52.63
65 52.91
70 53.20
75 53.48
80 53.76
Originally Posted by miami993c297
Hi Black02SS
0 49.08
5 49.38
10 49.69
15 49.99
20 50.29
25 50.59
30 50.88
35 51.18
40 51.47
45 51.76
50 52.05
55 52.34
60 52.63
65 52.91
70 53.20
75 53.48
80 53.76
0 49.08
5 49.38
10 49.69
15 49.99
20 50.29
25 50.59
30 50.88
35 51.18
40 51.47
45 51.76
50 52.05
55 52.34
60 52.63
65 52.91
70 53.20
75 53.48
80 53.76
Slight problem I should have mentioned, I was using Edit so the readings should have been grams/sec (20-100kpa) the readings you all are listing at pounds/hour, and 0-80kpa.
