Wide band that works with HP Tuners?
Restricted User
can anyone help me out? im looking for a wide band that i can make work with the hp tuners????
any pics or info would help
thanks
tony
thanks
tony
Pretty much any wideband works with HPTuners. I have used the LM1, DynoJet Commander and now exclusively use the AEM. So long as it has a 0V-5V output, you can use it with HPTuners very easily.
Restricted User
Ok how much does the LM1 cost and does that and aem just plug right in??
i went on ebay and found this aem wide band. Is this a good price or would i be getting ripped?
http://cgi.ebay.com/ebaymotors/AEM-G...spagenameZWDVW
If your looking for just a Wideband that works, the LC-1 is right up your alley.
I use the LC-1 and its much cheaper than the LM-1 due to less functionallity (HP tuners takes care of the lacking functionaliity) All you need is the 0-5v output and that is what the LC-1 has!
Innovate Motorsports LC-1 can be had for about $200 and it comes with controller, Bosch Wideband O2, Control software, and much more..
check out the video on Innovate motorsports website.. there are many sponsors here that sell it.. such as Green Light motorpsorts -->
http://www.innovatemotorsports.com/products/lc1.php
Plus.. videos for both LM-1 and LC-1
http://www.innovatemotorsports.com/resources/lm101.php
Restricted User
Ok im set on the LC-1 i just use hp tuners for the acutal af numbers etc right?
http://cgi.ebay.com/ebaymotors/Innov...28958500QQrdZ1
199 shipped sounds good?
Moderator
I use the LM-1. Good solid unit, nice for when you are
going to use it on multiple vehicles.
People sometimes have trouble with the LC-1, its ground
scheme seems to introduce offsets if you aren't careful
and the outputs can be easily damaged. But it can be
mounted in the car permanently, cleanly.
If you're buying it used be sure you find out about any
electrical damage. Check out the HPTuners 'board EIO
section for various peoples' LC-1 troubles & solutions.
I don't really favor leaving the thing in the car all the
time, the sensors do wear out or foul out and it's just
another piece of clutter if your tune is stable.
