How much should LTFT go up with LS6 intake?
My LTFT's have gone up around 6% since installing an LS6 intake. This is a normal amount for it to go up isnt it??
Originally Posted by RedHardSupra
yup, i think mine did like 7, but it was also on a really cold day (february in chicago, yuck)
Moderator
I don't think the trims should move at all, it's just slightly
fatter pipe. The only place the intake should have effect
is up where you're well out of closed loop anyway. If you
see the low end cells being messed around then I doubt
the intake manifold is responsible per se.
Intake gasket sealing however should be double-checked.
