Hard Startup....Security
Old 09-26-2006, 07:19 PM
ScreaminBlackPONTIAC's Avatar
Default Hard Startup....Security
Have a 99 Trans Am A4...upon regular startup cold or not...when i turn the key over nothing happens as if its a dead battery. when this happens the security light comes on. if i release key and try again it will either do nothing or start then die....upon third try it wil startup. I talked to Dealer and they say they can fix it for 250-300. Is there anyway i can figure out the problem instead of the dealer diagnosing it? any help is appreciated thanks
Old 09-27-2006, 05:11 PM
2001NBMZ28's Avatar
Sounds like it's not recognizing the key. Could be dirty key, ignition switch, wiring, etc. Search for VATS bypass or security light.
