Ls1 Edit help!
Old 10-02-2006, 08:28 AM
blown402's Avatar
Default Ls1 Edit help!
I'm new to using this software. How do you delete the downstream o2's and the egr using ls1 edit?
Old 10-02-2006, 08:35 AM
brad8266's Avatar
go to where the codes are. then select the codes you want to delete and click on it. Then go to small drop down and select X , it says do not set MIL or something like that. Once the codes are set to X, they will be deleted out and will not set the light off anymore. Then just save the file and reflash your PCM.
