Mail order tune
Old 10-07-2006, 12:57 AM
yobabiesdaddy2001's Avatar
Default Mail order tune
I already have a mail order tune from tsp. Now that I have Hp tuners where should I began tunning? I was thinking that I will only need it for wide open throttle tunning (using a wideband). Car put down 410/379 H\C.
Old 10-07-2006, 08:23 AM
ZL1Killa's Avatar
well, first of all grab a stock 2001 tune file from your make model car. download your cars current tune, take a look and compare your cars current tune to the stock tune
take a look at spark (timing)
take a look at your PE table
your VE table
MAF table (MAF and VE are blended below 4krpm and non-WOT... contributes to high or low fuel trims)
MAF is simply WOT... that will adjust your fuel up past 4krpm
check to make sure cat protect is off.
then setup a bunch of histograms/maps/ select things to log.
monitor KR and current spark. monitor fuel trims .
monitor fuel if you have a wideband
Old 10-07-2006, 10:25 AM
thanks for the info, keep it coming.
Old 10-07-2006, 03:08 PM
chrisj6's Avatar
hey man, when we meet up I can help you out some. We will compare the files and set you in the right direction!
