ve tuning... smooth it out?
smooth it, you can use i think both efi live and hptuners to smooth and leave max cells or smooth in general. i most of the time use both, as just smoothing sometimes lowers it too much
Kleeborp the Moderator™
You can click and drag, or you can just highlight whatever cell you are interested in, and then you can increment it by hitting the + or - buttons on the keyboard...it'll increment by whatever your accuracy is (like .1 if you table reads to the .1 decimal place).
Yep, same here. Initial VE will be very approx due to not all cells being filled so hammer the whole thing into a nice shape. Futher iterations will require less violence until at the end only regional petting will be required.
Moderately Differentiated
Originally Posted by 02sierraz71_5.3
bump decimals out to X10^5 before smoothing works great resolution
