Traction Control Mod
Ok so you guys know SLP sells this module that makes traction control set to off when you start the car. I was wondering if I can do that without the module. Is it possible just to tune it so that the traction control will be off? is there any other way? I just always turn it off whenever I drive and would like to keep it off by default. Thanks in advance.
Moderator
If you unplug the relaxer it just faults to ASR OFF. No
action I could detect.
If you fool it into thinking the relaxer is still connected
it will apply retard, (bogus) relaxer and ABS in that order.
The ABS is not fun. Hoped it would be a smart traction
improved and instead it just clamped down hard and
made unhappy noises, all 16 seconds' worth of the 1/4.
Hey, you don't know 'til you try sometimes.
Originally Posted by MeentSS02
Noper...the traction control system uses a different computer that we don't get access to with HPT or EFI.
