quick easy questions
7 Second Club
in the VE table when you put larger values in, are you putting more air in the motor or are you putting more fuel in the motor?
what AFR do you guys consider Lean and Fat?
what is considered safe?
Thanks,
Tyler
Thanks,
Tyler
LS1TECH Sponsor
The default units for the VE table are (grams*Kelvin/kPa), which to me sounds like airflow. More airflow requires more fuel. Therefore I'd say when you increase the VE table, you're telling the PCM, "This is the amount of airflow the motor will see based on the current temperature and barometric pressure."
Generally for a blown tune, I believe people shoot for an AFR of 11.8:1 for the street.
How much boost are you running?
7 Second Club
maybe the VE is telling the computer this is the certain amount of air you will see at this pressure so then in turn it adds more fuel... when in reality its not really seeing that much air but we program it that way to make it dump more fuel....
i could be way off, but sometimes i feel like i learn more when im involved in a discussion.
