my procharged car is making 250+ temps
7 Second Club
wondering what i need to do.... is it the hard ware or software...
the car when just easy driving hits up over 230 pretty quick... then it goes to 255 really quick...
what could be causing this... the A/F is about 12.5 when just driving around...
timing is around 23* when just driving around also..
7 Second Club
its a totally new setup... motor and everything...
i have the one ATI fan and shroud... and yes that ****** is HOT i can hear it boiling....
it is the stock rad with the one POS ATI fan and shroud... and yes i can hear it blowing.... the car tends to cool off some while idling... but when moving at any speed it gets hot
i have the windshield washer tank gone along with all the AC stuff...
im thinking about putting 2 pushers and a large new Rad. up front since i dont have AC or anything else in the way...
so i guess its the same common problem the other ATI guys had on their F body isnt it
7 Second Club
Originally Posted by foff667
air bubbles maybe? blockage in front of the radiator? do you still have the air dam in tact?
should be like 14.7 cruise (stoich), 38* ish timing. until under load.
dont wanna sound like a dick here but make sure the fan is blowin the right direction. if its wrong, at cruise it will fight any air comin through the rad, and at a stop it will push through air, cooling it somewhat til u move again, like u had described. it could happen.
7 Second Club
Originally Posted by Old Geezer
12.5:1 at cruise, seems really fat....
Timing at 23* at cruise, seems low...
If the temp is "reasonable" at idle, but high at cruise, could be a compression leak into the cooling system.
Compression test? Maybe a leakdown, too?
i was just trying anything to keep the temps low with more fuel and low timing...
7 Second Club
